wiretwister
Just got my 8BA block home from cleaning and magnaflux.
Has only one crack that I believe is repairable. See last picture.
There are some unusal stampings on the machine surface where the intake manifold bolts down. Could some one interpet the markings for me please?
First picture is on left bank between the intake runners at front of the block. There is a W-3 in large letters. There is a single E. Then there is two A's or maybe 4's. The A's are not in a line like the W-3 is. I do not recall ever seeing this kind of marks on a Ford Block. What do they mean?
Second picture is a single L and one large 2 and one small 2, They are at very front of the block on the driver, left side in front of the first intake runner. What do these 3 marks indicate?
Third picture is a single C located between the intake runners at the rear of the block on right or passenger side. What does the C indicate?
Fourth picture is of the one crack in the block. I believe it can be pinned and a new valve seat cut in for a relativly inexpensive repair. Other wise the block is in excellent shape.
Background info: The block has been rebuilt some time during its lifetime so it could have come out of something other than the 50 Ford I knew about. That rebuild changed several things: Pistons are +.040 and the cylinders will clean up at .060 with no problem. There is no ring wear ridge at top of cylinders. The crankshaft has been cut to -.010 mains and -.020 rods it is good and will be reused with no changes to those numbers.
Sure hope someone in the Ford Barn Knowledge bank can help me to understand these numbers.
There is the possibility that at least some of the stamped markings were marks put on by the previous engine builder to idintify his work.
Thanks for all you help -------- bill
