All good comments above ^^^^
Which intake manifold do you have? Since you're looking at 4bbl carbs and your motor is 'stock', I'll assume you have either the ECZ-A or ECZ-B manifold. The carb bolt patterns are not the same (the 'B' is larger).
If you have a 'B' manifold and aren't looking to spend much you can scrounge around for a decent used 289 or 302 4bbl and probably get it rebuilt at a good carb shop for about half the total price of a new one. (call & confirm their prices first) You can probably find a small good used Autolite for almost nothing since they don't have a fancy name like Holley & Edelbrock.
A carb with vacuum, not mechanical, operated secondaries will self-adjust to the intake flow & throttle position. That said you still don't want to get something too big and over-carb the engine. 500 cfm is probably a good size for a stock 292 engine.
With an 'A' intake manifold you'll most likely need an adapter. That bolt pattern doesn't fit many carbs, and the 'A' doesn't flow as well as the 'B' manifolds. Staying with a small-ish carb (450/500cfm) should be good.
ALSO, what year is your engine? Does it have the original Carb and Distributor?
55's and 56's each had one-year-only vacuum/timing advance setups and they won't work correctly with anything else.
