I believe there is a spiral spring behind the dial one end of the spring is tied to a adjustment arm. the pointer position and the adjustment of the spring work together to make the speedometer read correctly and return to zero. the pointer is removed by pulling it straight out, there is a tool to pull this from the rear of the pointer. Try the spiral spring adj first.
