Dave,
That must be a drilled crank to feed rods?
What is the ID diameter of the popoff valve?
The attached photo shows an alternate way to decrease the oil pressure to the rear main bearing. The installed pop off valve will keep some flow to the bearings and the modification is hidden from sight. If you are wondering about the carb jet you see: I have restricted the oil flow to the cam bearings in the photo by installing a carburetor jet... I am developing about 45# of operating oil pressure in the system.
I am not sure tapping three holes directly into the oil galley and drawing off oil flow will provide enough flow without being detrimental to your engine's bearings. Time will tell. Hope it works.
Good Day!
