I'm restoring a 40 Ford P/u for a customer that was built in late 50's. I'm finished back to the rear end. It has a Halibrand Q/C center section with 10 bolt axle bells bolted to it. It has open drive shaft with U-joints. The axles are flanged at the outer ends. The wheel cylinders bolt to backing plate with 2 bolts. The shoes are 11x2 with star adapters at bottom. I believe fords up to 53 used 3 bolt mounted whel cylinders. I have never disassembled a Q/C rear and need to remove the axles to replace the axle seals. How are the axles removed and what years are these types of brakes common to? I have been assured this is not 32-53 ford brakes. Any help will be appreciated. Bob
