DavidG Well-known member Aug 23, 2024 #21 The lamps themselves appear to be '35-'36, thanks to Trevor's photos.
mercman from oz Well-known member Aug 24, 2024 #22 1935 and 1936 Ford Tail Light Housings are completely different. 1935 Ford Tail Light Housing. Notice the added piece at the base.
mercman from oz Well-known member Aug 24, 2024 #23 1936 Ford Tail Light Housing. Notice no added piece at the base.
mercman from oz Well-known member Aug 24, 2024 #24 The 1937 Australian Ford Tail Light housing is Cast, unlike the 1935 and 1936 housings that are Pressed. This side is Part Number 78-F-18470 The one that sjaakslinger has is Part Number 78-F-13471
B Bob C Well-known member Aug 25, 2024 #25 If that should be 78F-13470 the parts book shows "Bracket and stop light-rear-Australia only" but does not show RHD.
sjaakslinger Senior Member Aug 26, 2024 #26 Ok, so it seems like I have an Australian '37 LH side tail light bracket.... Still weird that it ended up in The Netherlands.[emoji848] Verstuurd vanaf mijn SM-G781B met Tapatalk
