help needed on tail lights 1933 sedan
FrankWest
Need configuration for the two tail lights on a 1933 ford sedan.
I need to purchase everything for them.
The brackets, the light assemblied, the license plate hold and is there a special light for the license plate light.... please help with configuration of what parts I need to assemble the tail light assemblies and license plate holder bracket.
Attached is the 33-34 Tail Light Assy. You should be able to use the Ford part numbers to identify the supplier part numbers. These year of Fords had one Tail Light, some individuals add an additional Tail Light so that you have a pair. Also, original Ford tail lights do not have turn signals, but these can be wired in as an aftermarket unit.
I just started repairing mine. These are 33 tail lights. The one with the plate bracket is for the R side in my car (RHD car). Yours probably is a L hand drive so the plate will go on the left. The "exploded" view shows all components, just as on the previous message diagram. Joe's antique auto has all the replacement parts if you need them.
I see some tail lights with a center blue dot? What the heck is that?
Not original?????.
I see several tail light bracjets that are rather beat up, is that tyoical for originals or is that just junk and better pieces can be found?
does part number 13471 light stands used 2 separate bolts to bolt to fender or are these 2 bolts intergral to the stand itself??
I found on stand that has only one bolt and a square hole where the other bolt should be.
