help needed identify 32-33?
Thanks for the kind words guys. That only points to the sign of a misspent youth; too much time with my nose in books, but they were the wrong books!
Fordors is right on the money. Front of the cab from a '33 panel delivery, with the back of the cab made from the rear panel from a '32 sedan.
i want to say thank you to all for the info so far. after reading the posts, i now think is was a panel truck when it left the assembly line and later on it was converted it to a pickup. here are some more pics i took as it was raining this morning. i checked the plate on the engine and it was blank. the plate above starter is very hard to read but i can make out most of the numbers which match the title. i was told that possibly the gear ratio is stamped on axle. can anyone tell me where to look for that?
here are some more pics.
and last of pics.
You see that rib running up the middle of the axle center section? There's one underneath, too, and the numbers should be stamped into that.
Mart.
