One quick way to overcome a problem you are describing is to have a spare distributer that has been run on your car with the timing set for your car. You also should have a by-pass cable. You can make one from a discarded pop-out cable connector or you can buy one ready made.
Bratton's has them for $14.75, part number 16360. It is called an emergency Ignition jumper cable.
If you are not getting battery voltage to the ignition points, yet voltage is present to at least one side of the coil, it means there is either an open or short at the ignition key, inside the pop-out cable, at the connection to the distributor, the wire on the lower plate in the distributor, the connection to the points under the upper plate, and a possible shorted condenser. Anyone one of these could be the fault.
To quickly get the car back on the road if you are stalled alongside, replace the distributor and connect the bypass cable to it, put the clip lead on the low side of the coil where the red wire should be. remove the red wire first.
You have now by-passed all the fault possibilities described above and the car should start right up. You will have to remove the clip lead from the coil to shut the engine off.
You can drive the car indefinitely this way. However, the task is to locate the open or short. This can be done by disassembly and inspection of the distributor and checking the pop-out cable with an ohm meter.
I carry a spare distributor and by-pass cable with me and have had to use it several times along the road when a fellow club member drifted to the side of the road. The first cry that usually goes up is "change the condenser". It is much quicker and provides positive results to change the distributor and hook up the by-pass cable. You do have to re-set the timing for a different car.
Tom Endy
