new problem . 1928 roadster . had the pan off to check bearings . rear main is .001 . when putting the oil back in it , at 3 qts it started to run out the rear main brg . what am i not seeing here ? thank you .. steve
tube was clear (ran a wire thru it) , new pan gaskets , no leak there . it appears to run right out the brg . actually cant believe it poured out with only 3 qts . so whats next my dear friends ................ steve
