wbedwards
'59 Edsel standard NO power brakes. Since I have had the car, the brakes and brake lights apply themselves when it gets hot. The previous owner put new front lines, new shoes, new slaves. I flushed the lines, replaced rear soft line and rebuilt the original master cyl. I can hear/see the slaves working. I've adjusted pedal rod as far as it will go. I can drive it while its cool and it feels normal, but when it gets hot pedal gets real stiff and brakes come on.
I can run a heat gun on the master Cyl and the brakes and brake light will come on. How can you put new parts in a master cyl. and it still do that?
Only fix is another master cyl.?
thanks for your thoughts
