Help me to identify this bracket!
DocJohn
I've been going through various bits of bracketry from the front end of my V8 Pilot Woodie, remembering that the car has been dismantled since the the late 1970s and I bought it in 2014 as a pile of bits. The part I am struggling with is a pressed steel bracket, of which I only have one. It looks like there should be a matching handed one. I've no idea where it fits - the holes don't seem to line up with anything on the frame rails - or what it does.
For those of you who are not familar with the Pilot V8, in chassis terms it's basically a post WWII UK built '37 Ford with an antiroll bar on the front suspension.
Thanks!
Guessing here...is it a bracket that ties the upper steering column bracket to the bakelite dashboard?
Solved! It's the bracket inside the wing that the headlight bolts on to. Just need to find the matching one for the other side...
