Oldman Freeman
- City
- Centralia
- State
- WA
- Price
- 1800
Included are a rolling chassis (which is available separately), one rear fender with taillight and bracket, one emergency brake crossbar, one stock exhaust manifold, one set of clutch and brake pedals, two headlight bars (one with some extra holes but no rust), two running board brackets, two running boards, two stainless cowl bands, two heater type exhaust manifolds without covers, two service brake crossbars, three front bumperrackets, two steering wheels, three steering columns and spare parts, two (poor) front fenders, two running boards, two pairs of engine compartment splash pans, three rear ends with extra parts, five intake manifolds, four bell housings, four engine blocks (three with cranks and cams and two with valves and pistons too), four complete transmissions, four headlight switch/horn buttons (one is a 29 that is nicely chromed), four front bumpers, four flywheel housings, four pressure plates, five rear "bumperettes", five shift levers, five transmission cases with other misc. transmission parts, six stock heads, six pressure plates, nine clutch disks, a box filled with water pumps, a box filled with water necks, a box of engine internal parts, a box of engine external parts including , a box of new and used ball bearings, several generator and starter cores (some of which may be work with minimal effort), ten front backing plates, seven rear backing plates, ten front brake drums and six rear brake drums, one big box of inner brake parts, thirteen wheels, and quite a lot of other miscellaneous Model A parts. All for $1800 with the chassis or $1300 without it.
