Canton_Model_A's
Good day to all the members. I am having an issue with my left-rear service brake on my A. The actuating shaft/lever is extremely hard to move. Should this be easy movement or stiff. It is causing the brake pedal to not return to normal position. Also when I apply the brakes it takes a lot of effort to stop the car, kind of like if you have massive brake fade. I know the Model-A is supposed to stop on a dime.
Regards
Dave
Regards
Dave
