Need help installing the pins that go into the spark and throttle levers on the rod ends, let me know tips or techniques that you used to peen over the ends of the pins.
Thnx, found the post, just used "throttle" in the search to find it. I was over thinking the search, kept using "spark and throttle". Unfortunately the steering column still in car, don't know if I have enough room to peen, just going to use split pin, mot a fine points car.
