PB Blaster/WD40 more to clean/flush the dirt out, then a good quality lock lube. Make sure you lube up the locking plunger, you may have to remove the 2 screws holding the drop to the bottom of the dash to get to it. Jack up the front axle to get the weight off the column. What does the key look like? if it is badly worn it may have finally gone over to the dark side.
