Help! Ignition Issues on 31 Model A
Lamar Green
Replaced ignition switch on my 31 Model A Roadster and now the car will not start (it started before with the old one)
I have spark at the points and then smoke is coming out below the point set inside of the distributor for some reason?
Can someone help me with the wiring route from the switch to coil to distributor not sure if I've crossed something or not....
Any help would be greatly appreciated, thanks!
Go the the Model A discussion section and ask your question. - this section is for questions about the site itself.
