Im working on a 32 ford coupe with dual master cylinders.
Im trying to find rebuild kits, but I can't
make out the part numbers completely. also, it seems that the
bolt holes are an odd spacing (It seems).
Also, I don't see any online with circular extrusion on the sides like these.
They are stamper FoMoCo.
Specs:
Bore Diam 1"
Bore Depth (If I'm measuring correctly?) 4.5"
Horizontal mounting bolt distance center to center 3.75"
Vertical mounting bolt distance center to center 2.375
(There were no pistons in the cylinders)
Part numbers appear to start with AA 21???
Specs:
Bore Diam 1"
