Help identifying heads, clocks, and a KR Wilson Tool
fgaller
Hi all, as I go through my late fathers collection, I have found a few items I'm looking for some help identifying. I have now found a total of 3 sets of the 81A-6050-B high compression heads, 2 sets are NOS in the box. The other heads I'm not so sure about. Also, curious if the KR Wilson tool was somehow related to these high compression heads, as it shares a very similar part number. Attached are the pictures.
51 heads are 60HP Ford, 37 - 40. Some value, not much.
KRW tool cuts the relief for the valve chamber in cylinder heads. This has some value. On ebay, maybe $150.
Clocks are '40 Mercury as has been advised. Little value. Some, but not much. Maybe $25 each.
The A head is 39 / 40 Ford. You may be able to give it away.
Thank you!
