Picking up this 39 Truck. Will need some replacement parts so looking for some help identifying which model it is. IS this a 1/2 ton, 3/4 ton etc?
I measured 122" wheel base and it has a wooden flat bed to it. Looks like its been slightly modified over the years. the front fenders are split and the whole front tilts forward and someone added fender mounted signals. Not sure on which hp engine so will need to check it when I get it home. She fires right up and sounds great! Po said he had the wheels modified to accept 16" regular beaded tires, although I'll admit I have no idea what that entailed.
Previous owner says the wheel cylinders leak slowly even after him rebuilding them. I plan to replace them along with the rubber lines. Will need to evaluate the hard lines to determine if I should just replace them while I'm at it. Master cylinder was also rebuilt, but may just buy a whole kit to replace everything. Regarding the hard lines, will anyone have a pre-bent kit for this with it being the 122" wheelbase?
I'm sure I'll have a ton of questions coming, but loving the wealth of info I've already read on the site!
