Help ID some parts
1EarlyA
I need help to ID some parts I got recently in a load of mostly pre-1950 Ford parts. I am not sure if these belong here or in the Model A section... I just made a guess.
The assist straps are slightly different than the Model A ones I have seen. I found one other pair like them online and that person didn't know the application either.
I don't yet have any information about the switches.
I have seen similar(possibly aftermarket) tubes listed as road draft tubes for Model A or flathead V8... but again with little certainty about the correct application.
Any info would be appreciated
Thanks
BTW if anyone here is familiar with commercial trucks, I have a couple other pieces from '60s(?) trucks. If you think you can help with those send me a message. Just didn't want to put those here since they don't have anything to do with Fords specifically.
Thanks
The switches are all after-market. In other words, not a specific automobile make. That "double" switch and panel will bring a decent price on eBay.
The breather tube is also after-market. Fairly worthless value wise.
The breather tube is aftermarket Model A I believe, and the double heat switch would be from a bus I would guess. Nice looking pull loopy things if we knew what they were for
