How do I remove the starter bendix cover ? I'm having trouble engaging the bendix to the flywheel starter ring.
My problem is with my 1937 Ford with the stock flathead engine (80hp) and stock flywheel .However, I installed T5 trans with the open drive shaft conversion. It appears that the bendix is engaged to the starter ring( won't return to the normal position ) Mind you its on the hoist right now. I'm thinking the best way to free it would be to lower it to the ground -push it in reverse - pop the the clutch -enabling bendix to return to the normal position
. what do you think ?????
I suggest that you find the problem BEFORE installing engine. It sounds as if you have mis matched parts 1 JMHO good luck. kerk
