Seth Swoboda
If the radiator has not been or recently been removed and "rodded out" or thoroughly cleaned then I would do this also. It will not be the fastest fix or the cheapest but when the venerability of the flathead V8 is heat then a radiator that is not functioning at 100% efficiency will give you lots of overheat problems. I have the radiator out of a '35 Ford now for this very problem. I also did this procedure to a '47 Ford last summer and it solved the run hot problem.
