Y-Blockhead
... has power to coil, cranks but won't turn over.
But do you have spark at the plugs?
Another check would be take the coil wire and hold it a quarter inch for my head bolt and crank it and see if you get a big blue spark then you know that the primary is working...
A "new battery" used to mean a good battery. Unfortunately not all current "new batteries" are good. Charge it and take it somewhere (the auto parts store) and have it tested under load.Update--will be having a friend coming over tomorrow evening (hopefully). Today some strange goings on, I would (at times) get voltage reading all the way from the battery through switch to coil then I would "crank" it just a couple of times, still wouldn't turn over. Took voltmeter directly across battery terminals and zilch/nothing. Checked water level in battery (down just a little), filled it and now have a charger on it (again). Bad battery? If I could get a photo loaded you can see it is a fairly new battery, which was also offered up by previous owner. Oye ve!
