Hi all.
So I need to replace my crank pulley, going with a one piece. I removed the motor mounts screws, ****** frame mount screws, and gas pedal assembly.
The gas pedal assembly was hitting the fire wall when I was jacking the motor up. I jacked the motor up all the way till the rear head bolts hit the fire wall and my pulley STILL WON'T CLEAR???? Do I also need to remove the front spring shackles?
RANT!!!
I don't know HOW THE HELL the former owner of my A did not kill himself! I've only had my A for almost 2 years and I can see everything f-ed up on it. Which seems to be everything I take apart. The two piece pulley that I'm replacing was practically swinging front the crank. The second small piece was split in two, and had been banging around so long it wore the edges down. WTF!!! I love my A but christ sake I should have just started with a frame.
Thanks all!
Banky
RANT!!!
Thanks all!
Banky
