TomInCologne
help! clutch won‘t disengage…
okay, managed about 30mls before…
the clutch pedal fell to the floor, clutch won‘t disengage but i can see the ‚clutch bearing‘ move in and out when i move the pedal…
i noticed before that the clutch did not want to disengage, i heard some grinding whilst changing gears.
the adac/rac/aa is on its way but it will be some time before they arrive…
what has likely happened?
is there anything i can do right now?
Edit:
1 week later, Solution: The clutch arm was broken! The bearing hub was moving in and out but still, the link between pedal and clutch was broken. If this happens to you, really thoroughly check the clutch arm. See the photos of the broken arm later on in this thread.
Edit:
