Texas Tom
Got a flat tire on right rear wheel first time out with my newly restored 1930 town sedan. Jacked up car and easily removed all lug nuts but one. With great effort, the last lug nut BARELY turned. Tried an impact wrench, and again it barely turned.
Seems the lug and the nut have somehow bonded, and the lug is spinning with the nut. I cannot make the nut come off, or spin back on so it's tight.
Problem is I can't get the rear wheel off to get at the offending lug from inside the drum. My conventional clam-style puller won't work when the wheel is on the drum because there's insufficient clearance inside that portion of the wheel.
I've taken the nut off the axle, turned it around, and beat on it to try to loosen the hub. No luck. I've done this with the brake adjusting pin backed all the way off, so the shoes are not holding the drum.
The drum, lug and lug nut are all brand new. The lugs were all properly seated when I assembled the brakes.
So, my friends, what sayeth ye? How can I get that #%$&@ wheel off?
