fivefix
I was breaking in my newly rebuilt engine on my 1930 Tudor and hit disaster at 132 miles. I noticed a small amount of antifreeze dripping out of the radiator fins (I was driving with the hood off) and a little steam exiting as if a tube was leaking. I immediately headed for home and the bottom seam of the radiator reservoir blew as if it was pressurized. Steaming hot antifreeze blew everywhere. I have melted solder on the radiator and engine and quite a crack in the seam. I was running 50/50 Prestone mix, changed the oil at 100 miles, installed a Vintage Precision thermostat housing and am running on the original radiator. I pulled the thermostat and it opens fine at 180 degrees. We cranked the engine and the water pump rotates as it should. We also added water to the radiator and the overflow is not obstructed. I torqued the head nuts after an initial engine warm up and cool down and after 35 miles.
It's 85 degrees in Iowa today, mostly cloudy and I was driving between 35 and 45 MPH with most of the miles at 40 MPH.
Attached is an image of the blown seam.
What did I do to cause such a catastrophic failure of the reservoir seam? If I was losing a substantial amount of fluid, (no puddles anywhere) could the engine overheat and build up enough pressure to blow?
Thoughts?
Thoughts?
