Help! 1933 Distributer
fourfords
Is there an expert who can troubleshoot and rebuild my stock 1933 distributer? hopefully in the Southern California area?
D. Stewart
951-334-9544
dirkstew@aol.com
Hello there.
If you have no joy in finding someone to rebuild your 1933 distributor I have a factory rebuilt one with the correct part numbered shaft for 1933.
Only problem is I am in New Zealand and postage will be expensive.
I have a contact in Ojai if you need a reference.
Cheers
Graham Freeman
FourFords
Not in So Cal but Michael at Third Gen Automotive (TN), Charlie Schwendler Aka Charlie NY, "Me" (Fla) to name three BUT I am sure there is someone out west that is quite capable BUT IF you don't find one....here are three.
Just my opinion BUT where it me....I would buy a "back-up" distributor and coil to "ALWAYS" have an insurance policy (so to speak) so you can always have your car going and IF there is an issue you are not stuck while the other one is being repaired. Not sure BUT IF you haven't had your coil rebuilt by Skip Haney in Punta Gorda FL, now would be the time to do so since your distributor will be off and out for rebuild and an extra coil wouldn't hurt either.
