Notice in the photo part of the ring casting is missing.
I assume the emosed ring is to seal against oil leaks. Should I be concerned in using it? ...or does it just hold it in place and don'tworry?
Thanks,
Paul
smear some 515 on it that will seal it
So what is 515?
515 is Loctite anaerobic sealer that has a jelly consistency. Good for metal/metal flange sealing that may need to be removed later. Needs a decent flat surface but fills imperfections nicely.
