Zeke3 may be on to sumpthin, I know the earlier ford solenoids will stick when mounted upside down. It seems they need gravity to help the spring unload the connection
It sounds loke the engine trys to fire, and the engine kicks out the starter bendex. with the starter drive kicked out the starter will spin very fast it has no load on it, it will not stop intill you take your finger off the starter button. The starter will opperate eaven with the key offDick is referencing a problem I am having starting the truck. While trying to start the truck, the engine turns and then the cranking stops and just the starter engine runs continuously until I turn the key off. My inexperience at first thought it was the engine (even though I knew it didn't sound like the flathead engines I heard in youtube videos I have watched) and I was confused the fan and pulleys would stop. I will try to post a video.
Today I took all the spark plugs out. All the cylinders have some compression and all the spark plugs spark. I double-checked that again. I did that during the summer when I bought the truck.
photos
I watched your video , so when you turn off the ignition switch,will the starter stop spinning? when you turn on the ignition switch will it crank? the ignition switch is opperated by a key , when you turn it to the left it turns on power to the coil and opperates the gauges. then the starter button is on the right side of the strearing wheel. can you read a wireing diagram? i wonder if the wire that opperates the starter solenoid is hooked to the coil side of your ignition switch. dose your ignition switch opperate like a modren car, turn to the right , first ckick would be on, power to the coil, then one more turn to crank, hope this helps,
Brendan
https://images.search.yahoo.com/sea...d66cbbdbf2e0108cd587cf3b3062.jpg&action=click
hope this helps its a Ford wireing diagram for the starting circut
Brendan
i think if your truck is a 49 the battery is on the driver side, don't be sorry for lack of knowlege. its all learning experiences we all have to learne sometime, wireing is very confusing for some people , Just keep the smoke in the wires...LOL
