1Metalbender
Figured I'd take a minute to introduce myself, seems customary to do so in forums however I did not see a place to do so here. I'm a bodyman by trade for the last 30 years and finally decided I needed to build something that I've always wanted. My current project (still in the acquiring parts phase) is a 30-31 model a truck, to far I've got a 4" drop and drilled front axle which I plan on running suicide. 37-48 spindles, disk brake rotors and caliper brackets (has to be able to stop to be safe) spring behind front radius hairpin rods with ford tie rod ends. A 52 ford flathead v8 motor and trans from a f4 and the majority of a 30-31 cab...my plan is to build a period correct traditional with the exception of the front disks which I'll probably hide inside of a set of drums. This is my first dealings with a model a so I'm sure I'll become a nuisance asking questions (mainly how the body's was constructed) but I hope I won't be a bother with it. I look forward to scouring the for sale section for the bits and pieces I still need as well as searching for what others have done with their builds
