Hello from Payson Az
az58cameo
Hope i can post my first post here!
I Inherited my Grandfathers 1929 Model A Tudor Sedan, He used to drive it back and forth to his Barber Shop in Detroit Lakes Minn, There are so many Great Stories that my Dad & Mom told me of this Car, I will Cherish this Car for the
rest of my life and will be passed down to my Son.
Its all Original except it has 32 headlights on it,it does run but i need to get a new starter for it, (shaft is bent and needs a new Bendix)
anyone have a suggestion to were to get a Good New Starter?
Thanks for your Time!
Allen
You have found the best online place for help. Masters of the A are ready to assist you (along with the rest of us.)
Look up and join a local club.
There are two national clubs MAFCA and MARC
http://www.mafca.com/chapters/AZ.html from MAFCA
and MARC
Model A Restorers Club of Arizona Region- 2010
PO Box 5255
Mesa, AZ 85201
Robert Ingram
480-947-1820
beehive8@cox.net
Arizona Model A, L.L.C
15838 South Gilbert Road
Chandler, Arizona 85225
(480)782-0266
They should be able to help with the starter along with many others listed in the top of this forum labeled;
" Model A/AA Ford Websites...Can YOU add to the list?"
Again, welcome, and I congratulate you in keeping the car in your family.
I made this tool to straighten armatures. Just watch the large flat washer and nut on the bottom as you rotate the shaft. When the washer is closest to the frame, you tighten the nut to pull the shaft down a bit. When it's straight the nut and washer will not bob up and down as the shaft is rotated.
You can also set the shaft on 2 V blocks and press down on the high spot in the shaft. They are really quite easy to straighten.
Replacement Bendix drives are available from the Model A parts stores, such as Bert's, Bratton's, Snyder's, etc. When you install the drive be sure the short bolt goes next to the pinion, and be sure the lock tabs on the washers are bent in firmly against the FLAT side of the hex bolts.
I assume by your avatar, that you have a Cameo Carrier. Nice. Got two my own self. Good luck with your A. Mark.
Yes i do have a 58 Cameo Pickup! & a 59 Chevy Stepside a 77 Ford Super Cab ,and with the Model A, The Garage is Full, Haha
Thanks for the Welcome Guys, i will try and post pic's
and i know i will have allot of ?'s
Thank you Very Much!
Allen
