I am in the process of trying to resurrect a 1930 that suffered a catastrophic engine failure.
Some specifics about the "new" motor, it has...
-new head gasket
-new timing gear
-carb from the old motor setup (refreshed using the procedure in Paul Moller's book)
-distributor from old motor converted to electronic ignition (timing set as outlined in Les Andrews' book)
The car does run, but
-It will only idle at a speed well above normal
-it seems to take a long time to warm up (idle without a lot of throttle manipulation)
-It is running rough. (Whole car vibrates)
-it over heats when driven (hasn't been driven more than 1/2 of a mile)
And...
-I think it is only running on two cylinders (2&3)
It is getting spark to all four plugs, but disconnecting the 1st and 4th spark plug leads does not affect the way the engine is running. It will keep running if I remove either the second or third lead (but obviously not both).
Here are my questions...
Is it possible for the timing to be 90 degrees off? 180 degrees? (And the car still run?)
Am I likely to damage anything if I intentionally set the timing off by 90*, 180* , 270* to see if it is off by that much?
-new head gasket
-new timing gear
And...
