1928Pickuppain
SO I have been looking around for a heater so I dont freese my *** off on my 20 mile drive into work this winter. So far I looked at the maniflod heater and they are way to expencive and I hear they dont work so well. The other thing is one of thoughs new liquid heater cores that you run off the cooling system. at $250 or so thats out of my range. So what im thinking is its junk yard time. Ill go salvange a heater core off some old truck or well something and set it up in a wood box that funnels into a hose with electric fans in it, the hose will conect right into my stock heater vent in my floor the small fans will be ones from a computer as they only run about 3volts some 5 volts Ill hang the box under the pasenger side floor bord and have the other end of the box comeing up from under the seat so the heat can return into and reheat even hotter. Has any one done this before and what type of heater core did you use??
