50fordcoupeman
My avatar has a 1971 302 engine. The car has the original heater. The heater control valve doesn't shut off completely. The NAPA parts man THINKS the current valve is installed on the wrong heater hose. My question is does the valve go in the the line coming from the water pump or does it go on the line going into the intake manifold?
Thank you!!!
Thank you!!!
