malpais
Anyone have a junk late 39/40 ish heater motor beyond use? I have a couple Ford Script 40 heaters that I need little parts for. Mainly the seregated clip/ring that holds the bearings in place. Someone evidently had one of these apart, lost the ring and tried to RTV the bearing in place, and it spins in case.
Could also use a little clip that wires from outside case and brush wires solder to.
I'll use the NAPA motor described in past posts if I must, but would be nice to find original two speed parts.
Also, does anyone know the thrust movement that is correct for these motors? Lots of washers on shaft to adjust.
Thanks,
Gordon
Thanks,
Gordon
