Boeing
Original heater on my 1946 F1, because my 6v heater motor had some issues with the wiring, and due to the fact that the truck is now 12v I decided to change the 6v motor to a 12v motor. I realize that there are some modifications to accomplish in order to switch the motors. I cut the bolt extensions on the shaft side. Now I realize that the fan assembly will not sit low enough. It is about 1 inch too high. I could file off the ¼ inch collar at the base of the shaft. But the motor will still be close to ¾ inch too high. Has anyone completed this modification? If so, I would appreciate some help with this mod. Thanks
