ottoschmidt
hello i need help,
i have a stock 1940 239 flathead truck 1.5 ton all rebuilt . For two winter seasons now i would open the heater shut-off valve and have incredible heat in the cab .So the temperature has dropped into the twenties here in Pittsburgh and i take it out for my bi-weekly ride . i drove it for 40 minutes uphill and down hill and let it idle for an additional half hour . my temperature gauge never rose from cold to warm(pegged on C) and my heater is blowing ice cold air . never warming up at all . i disconnected the heater hose to the heater core on the firewall while the truck is running and it is dry not even a drop.Disconnected the other side to the heater core and not a drop to be found . the radiator is full.the shut off valve is turned on. the thermostats from C@G only 3 years old .I put my hands on the motor after an hour running and its not very hot . the bottom rad hose where the heater hose connects to is not very hot either.there is no pressure to the heater hose obviously . What going on guys ?
Best Regards
Best Regards
