heater a/c vac. motor
ohiojo
J C
ohio
I need a heater A/c vacuum motor for a 1968 Ford LTD 390 cu.Its a 2" cylinder shape with a 1/8" vac hose connection on one end and a flat shaft that connects to the defroster door also has 2 holes in the mounting bracket to fasten to the plenum on the left side of the firewall under the hood. Its the only one under the hood.Ive been on ebay etc. No help.All help is appreciated.
thank you Charlie
