MrTube
So, every often moving the headlight switch causes super dim headlights with high current draw which blows the fuse mounted near the starter.
If you turn them off fast enough and keep trying you won't blow the fuse. I was able to fiddle with it enough to get it to just draw the normal amount of current and as long as I didn't mess with the switch, it didn't have any issues driving around.
Any ideas? Obviously something in the switch must be shorting to something, but not causing a dead short.
Curious if any others have had such a problem.
