Will N
Ok, so I bought a new 5 wire commutator wiring harness, and it came with a wire for the headlight embedded in the loom, and a second plain black wire with no terminal ends on it. I imagine the wire in the loom for the headlight with the terminal end attaches to one post of the headlight switch, and the other bare end goes into one of the terminals in the passenger side headlight plug. Then I imagine that the plain wire that was provided starts from the other terminal in the passenger headlight and crosses over to one terminal in the driver headlight. But what wasn't provided was any kind of loom to protect the wire crossing over, nor was there provided a short wire to connect the other side of the driver light to ground, nor was there a wire to connect the other side of the headlight switch to the power source (either the mag or battery post on the coil box. Should these "missing" items have been included, or is the expectation that you should make these items yourself?
Thanks
Will
Thanks
Will
