Deucekoop
I think what everyone above is saying is that your recent wiring of the headlight switch doesn't explain this problem. Only one wire leaves the headlight switch to feed both high and low beams. Problem must be elsewhere, something mis-wired in the past.
Because its easy to get to I would look at the inside of the fenders where two wires connect into each headlight loom. Would have been easy to transpose those two wires, and easy for you to correct that now.
