38convsedan
The headlight switch is not centered when in the off position. (See photo).
The lights work correctly when switch moved to both parking and headlight positions.
The spider at end of shaft is installed correctly with the retaining clip.
The headlight wiring switch is fully seated at bottom of steering column.
As always, thank you in advance!
~Steve
~Steve
