Pilotdave
I have run into a puzzle with the headlights in one of our A's.
I'm using the new Bratton's reflectors and 50/32 bulbs. The reflectors are installed with the "Top" marking at the top. The slot in the reflector "tube" thus determines the orientation of the bulb socket.
Using a welding mask and with the light switch in the high beam position, I can see that the lower filaments of the bulbs are on; in the low beam position the upper filaments are on. The upper filaments are slightly offset from the center line of the bulbs.
Sounds good so far, right? Here comes the puzzle. I have been following the focusing process outlined on Marco Tahtaras's website.
With the lenses removed, I can track a 12" disc of light on the wall, about 5.5 feet in front of the headlight. I have performed the following several times, again using a welding mask to observe which filament is on: When I switch from high beam (lower filament) to low beam (upper filament), the light disc moves UP slightly - not DOWN as I expected it would. Is this normal behavior?
Thanks!
Dave
Thanks!
Dave
