coupe1942
I just opened up a brand new pair of headlight conduits with the horn conduit included. It has been sitting inside a plastic bin for a couple of months and has not been damaged there when stored. However, when I inserted the new wiring harness into it at the driver's side loom, the thing immediately spun open on me and opened up at one of the spirals near the headlight bucket. Grrrrr....
Any rate, from what I have seen in looking at various vendors, it appears that they all get them from the same place. That is an assumption on my part, but none look any different to me to indicate otherwise and the pricing seems to be the same anywhere.
Is there a specific vendor that sells a better quality conduit for headlights or is my assumption correct and you simply have to chance whatever you get?
I hate to put a black plastic spiraled loom about the conduit to at least do something with the part instead of just trashing it. Is there any way to repair the loom or is it not worth the effort?
It was not caused by any tension applied or by bending or stretching it during assembly to the headlight bucket.
What causes this problem? Any tips so it does not happen when I get the spare set ordered in?
Thanks........
Thanks........
