Head studs
Can someone point me in the right direction to find the installed lenghts of the head studs for a 35 with aluminum heads. I know I've seen it somewhere but over the years, sometimes I forgets.
Thanks
Check the Green bible. There are specific studs and washers for Alm heads.
40-6065 2.34" '32-36
40-6066 2.90" '32-36
40-4067 3.59" '32-36
351428 washer '33-37, use w/alm heads
Pages 231, 232 in the bible.
If we are talking OEM alum heads, which it sounds like he is.
Installing the studs is not the problem as I have done them before. Somewhere I would think there is an established/recommended dimension from the block deck to the upper end of the studs for each of the three length studs used on the 35 after installation. Taking a couple of measurements on studs that look like they are at the right length- the long stud is about 2-15/16 and the intermediate studs are about 2- 1/4 from block to top of stud. I haven't measured the short studs yet but will later today. I plan on using these dims to set the remaining studs. Thanks Bob
So are we saying the Green Book values (lengths) are not correct? I don't know, just asking the question.
