If you'll read what I said, I did not say tight. I said snug. Snug, by my definition, is just a little tighter than finger tight but not tight as in turned tight with a big wrench. Plus, if the studs are straight there's no reason for them to ****.
The bottom end of the Model A stud that screws into the block is made to a length of 3/4". The stud should be screwed all the way in to utilize the full strength of the 3/4 inch worth of threads in the block, as designed by Ford.
The original stud length of 3 1/2" for 11 studs, 3 11/16" for the ignition stud (on most Model A's) and 5 3/4" for the long front two are all the correct length so when screwed in to the shoulder, the height is correct to accommodate the thickness of the original gasket and the thickness of the original cylinder head plus the thickness of the original nut, with a little left over to protrude above the nut.
