Bob from Northport
In the process of restoring a Sport Coupe-1930-and was checking the headlight switch operation prior to installing the body back onto the car.
We installed a new wiring harness about 5 years ago when the frame/engine was restored.
I have the original switch off the car as well as another original switch.
When I install the spider fitting that attaches on the end of the horn rod, and use a screw driver to manually move the switch, it clicks in only two positions.
It should click on two one direction for low/high beam, and one the opposite for the parking lights.
A friend in Long Island said it might be the brass detents in the bakealite light fitting are not deep enough, and the brass light switch contacts are simply slipping past the contacts.
Can anyone advise what the problem might be and /or a solution??
Thanks!!
Thanks!!
