JohnSunliner
There must be a trick to pulling the head light switch out? I need to get at the wire connections but can not figure out how to unscrew the switch. It looks like the Bessel may screw out but the knob is bigger and doesn't.
The electrical contacts of the 6v switches may have a slightly higher current capacity.I don't know about 54, but 55, 56, and 57 Tbird ignition switches are the same for both 6v and 12v.
The old Ford switches do not take kindly to add ons when going to 12 volts so to take the load off add the relays on the headlights and the ignition switch as shown in the article,you can get these relays and the matching plugs at your local Fry's Electronics store for less $$ your headlights will be much brighter as a plus also and you won't have to worry about your ignition switch crapping out.
